good place to hide the amps
Old Aug 10, 2002
rp's Avatar
rp
rp is an unknown quantity at this point
where should i hide my amps
Old Aug 10, 2002
civic510's Avatar
civic510 is an unknown quantity at this point
You should hide them in the trunk! Maybe on the back of the rear seat? Mount it behind the subwoofer box? Underneath the front seats? It's pretty hard to hide amps unless you cover them up somehow.
Old Aug 10, 2002
Ed's Avatar
Ed
you could try a nice amp rack, or pop it under the floor somehow. If you have a sub in the trunk, i think it'd be safe to assume there's an amp around there too.
Old Aug 10, 2002
STang57's Avatar
STang57 is an unknown quantity at this point
Ed,
what kind of amp rack did you have in mind? i wanted to do a custom amp rack that will mount on the top of the trunk, but i havent really studied or gave much thought about it. do you have a good layout or idea for me? im scared if i DIY i might run into alot of problems like 6x9 magnets in the way or the trunk rods and so on. i was thinkin of makin it a tray, so it can slide out for easy show and quick access to adjust.
Old Aug 10, 2002
Ed's Avatar
Ed
I haven't really thought much abotu it, you could put it on the side like the other person said, or maybe you can use one of those keyboard type brackets that would alow it to slide in and out. I don't think mounting it upside down woudl be good without a fan, i imagine the cooling fins would not dissipate the heat well. You should just do a fiberglass thing on the side too.
Old Aug 11, 2002
STang57's Avatar
i wasnt thinkin about mounting it upside down. i know about the heatsink and stuff. i was thinkin about somehow making brackets that will give the tray couple inches gap from the bottom of the rear deck and mountin the amps on top of the tray.
Old Aug 12, 2002
MVHonda's Avatar
MVHonda is an unknown quantity at this point
this thread leads me to a questions, im building a sub box which will look like the subs are just mounted to the floor but im building the whole floor up about 3 inches or so, so i can place 2 amps underneath the floor on the sides, my question is would the area underneath the new floor be too hot for the amps?
Old Aug 14, 2002
Xudus's Avatar
Xudus is an unknown quantity at this point
I just put mine under the drivers seat, out of the way and it cant be seen, wich is a good thing.
SoyerOner
May 11, 2015 09:46 PM
LikeWh0a
Nov 27, 2001 04:24 PM
wawacito
Nov 5, 2001 03:32 PM
ChiFroBoy
Oct 24, 2001 01:32 AM
wsking77
Aug 30, 2001 12:32 PM
