[ Dual Voice Coil Questions ]
I am thinking about running the following setup:
* 1 INFINITY KAPPA PERFECT12.1D (12" Dual Voice Coil)
* MTX THUNDER 6500D AMP
My first question is, how would you wire this setup for 2ohms. My secondd question is, if the speaker is 350w RMS, is that 350 per coil, or 175 per coil?
wire both -terminals of the sub to the - terminal of the amp and likewise for the +. Also that amp puts out 800Wrms easy..that sub will get toasted if you crank it....
The Perfects are rated for 350Wrms total. 175/coil. But they can handle 500Wrms with music loads..
Civic65
Jul 19, 2015 10:13 AM
NoobyKid
Jul 13, 2015 07:53 AM
