Will this work?
Old Jul 24, 2002
LJ's Avatar
LJ
Fernando The Donkey Lover
LJ is an unknown quantity at this point
Will this work?
Ok, i want to put my amp UNDER the floor, with a plexiglass window, in front of my box. Well, my amp is running at 2 Ohm mono (yes it is stable at this load, trust me, 1/2 Ohm stable). anyways, it gets pretty hot, never overheats, but hot. well, i want to put 12v fans on each side, with vents on the top. should i have the fans blowing in from each side? or a push pull going across each heatsink? and do you think this will work to keep it cool, if i am confusing u, just pm me
Old Jul 24, 2002
Ed's Avatar
Ed
I'd say, if it was sealed, one in, one out. I don't know if you have ventilation in there, then maybe both out.
-Ed
Old Jul 24, 2002
LJ's Avatar
LJ
I am gonna have vents on each side of the plexi, like, speaker grill material
Old Jul 25, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
it should work help. if it over heats then put another fan on it. i would do a push pull method. push cold in and pull hot air out
werdnahall
May 17, 2015 11:37 AM
cruisers10
May 12, 2015 10:46 PM
intensity
May 12, 2015 10:43 PM
ORskier
May 3, 2015 12:54 PM
cooldan1
Apr 23, 2015 10:49 AM
