Spade connectors necessary? Ground wire?
Old Jul 22, 2002
klam's Avatar
klam is an unknown quantity at this point
I screwed up the spade connector for my ground wire (to attach to amp), so I substituted with one of the "o" connectors. Is there any reason that people recommend a spade connector for this connection?
Also, for my ground wire, I just put it under a big bolt under the seat. I scrapped away some of the paint to get a good contact and just sandwiched it beneath the bolt. Is this a good method or can I or should I use a spade connector or something for the ground connection?
Old Jul 22, 2002
mohawkboom's Avatar
Spades aren't necessary..just prevent the wire from moving around a little a fraying.. for a ground..it's highly reccomended to use a ring terminal for best connection...
Old Jul 24, 2002
Bdubb's Avatar
Bdubb is an unknown quantity at this point
nope your cool its called ghettofied just playin
Old Jul 24, 2002
klam's Avatar
Yeah, it does seem pretty ghetto!
Umm... a manual I have says that spade connectors should be used so that in an emergency things can be disconnected quickly. But I don't see how somebody would have to unplug their amp & sub quickly?!
BootyDo
Jun 21, 2016 03:45 PM
robbie374
Jul 7, 2015 02:56 AM
dinsum
May 28, 2015 09:30 PM
tmort
May 11, 2015 07:13 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
