amping the highs
Old Jun 27, 2002
prototype's Avatar
x-factor
amping the highs
ok i finished the trunk......now i wanna add an amp for the highs. i gotta HU that has a seperate out for the sub. now i know where to run the posotive and thr ground...where does the remote wire go? also i am goin with a 2 farad cap......how do u hook that up? not 100% sure and i dont wanna screw it up and yes i did a search. thanx
Old Jun 28, 2002
riceboi's Avatar
riceboi is an unknown quantity at this point
the remote goes to the remote on/off behind your (aftermarket) deck. the cap should go in between your battery and your amp(s) and depending on wether its an auto on/off, may also need a remote in.
Old Jun 28, 2002
prototype's Avatar
x-factor
ok i got the amps....no what gets hooked up to the caps? the posotive and remote or just the posotive? maybe if its too confusing ill get it done by some1.....dont forget im retarted
Old Jun 28, 2002
mohawkboom's Avatar
Okay...you run the positive wire through the positive terminal of the cap..then to your amps.. you then run the ground wire from your amps..to the cap..to your grounding point...
Old Jun 28, 2002
ce01cvcex's Avatar
ce01cvcex is an unknown quantity at this point
also, the closer that you put your cap to the amp, the more efficient it will run, just a tip
redcloud
25
Aug 12, 2015 01:23 PM
adamdrives
15
Aug 8, 2015 08:53 PM
Civic65
Jul 19, 2015 10:13 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
silentz
Jul 9, 2015 08:16 PM
