Making "sail panel" tight again?
Old Jun 25, 2002
klam's Avatar
klam is an unknown quantity at this point
After removing my door panels to install speakers i nthe front doors, everything seems to go back together tightly except the sail panel (the little triangle piece at the inner-top side of the door where the side mirrors are). It seems to move around a bit and is not as tight as it was before I removed my door panels. Is there any way to make it tight again?
Old Jun 25, 2002
pinoyVTi's Avatar
pinoyVTi is an unknown quantity at this point
did you check the clips? it could be that they got messed up...
Old Jun 25, 2002
mohawkboom's Avatar
you might have snapped off one of the clips or something..
Old Jun 25, 2002
GoCivicRacerGo's Avatar
GoCivicRacerGo is an unknown quantity at this point
Same problem here, my clips are intact but the driver side panel moves around a little bit. Really doesn't bother me at all.
Old Jun 26, 2002
klam's Avatar
The clips are intact, but it just moves around a bit. From the factory it didn't move much at all.
Vaguexo
Jun 13, 2015 04:11 AM
siCaddie
Jun 2, 2015 07:35 PM
RicoSuave
May 20, 2015 01:57 AM
TopFuel
Exterior
Nov 13, 2001 07:05 PM
