why is this amp overheating, or is it?
Old Jun 16, 2002
Canter69's Avatar
Canter69 is an unknown quantity at this point
i while back i posted about a kicker kx 400.1 class d mono Amp , i thought i was haveing a problem wit the ground, but i have messed with the ground and i know that it is grounded securely. The amp seems to cut off, i have the amp mounted on top the sub box in the trunk, and the amp was bought brand new. i see other rides with the amps enclosed in the floor and custom set ups like that and i never here about the amps cutting off! and i know my amp is getting more air then there's. should i think about moving the amp some where else! i have another amp in the car going to the rear deck speakers, and never have a problem with that amp.
Also i have 4 guage going all the way back then splitting and going to each amp with 8 guage, but i don't think that is the problem.
Please any help this is really pissing me off
Old Jun 16, 2002
mohawkboom's Avatar
Okay..what ohm load is that amp stable to?.. what ohm load are you presenting to it?
Old Jun 16, 2002
Canter69's Avatar
The amp is 2 ohm stable, and the kicker compvr 12 is 2 ohm dvc. the speaker is run in a series making the sub a 4 ohm load. is this wrong?
Old Jun 16, 2002
mohawkboom's Avatar
Hmm..you sure you don't have it running 1 ohm mono??.. Also..it is possible that you trying to overpower the amp. Like hae your gain on the wrong side and trying to make it put out more power than possible..
Old Jun 16, 2002
Canter69's Avatar
i guess i'll check my wireing, i'll be back!!! Also is this kicker amp a good amp or just am i just paying for the name? Any input?
Old Jun 16, 2002
ELaudio's Avatar
ELaudio is an unknown quantity at this point
Kicker amps are good - unless you have a defective one, which is unlikely. The majority of problems in car audio are caused by bad or imporper wiring. No matter how good you are at installing stereos, everyone makes mistakes. I have yet to build a system that worked 100% on the first go - and I've done 7 installs so far from the easy to the more complex.
Old Jun 16, 2002
Canter69's Avatar
well looks like i may have found the problem, the sub was not wired correctly inside the box. don't no what i was doing when i installed it. hopfully i have fixed the problem, guess i find out tomarrow when i bass home from work [IMG]i/expressions/face-icon-small-smile.gif[/IMG]. Thanks mohawk, your a god (or you just piont out the obvious)
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
raymondxcho
Sep 29, 2015 09:00 PM
Mc7602
Sep 17, 2015 02:01 PM
