Where to fuse....
Old Jun 14, 2002
pheaton's Avatar
A descendant of 2k1civic.com
Where to fuse....
I'm getting ready to do a big install. My system will be supported by a 1 Farad Cap. I'm wondering where do I fuse this set up?? Do I fuse between battery and cap? The cap and the amp?? or . .. both?? My knowledge of how this stuff works tells me that the cap is like a mini battery. . Therefore I think the only place I need a fuse is between the cap and the amp. . But tell me if anyone thinks otherwise, or knows otherwise. . So I don't mess anything up. . Thanks for your help...
Old Jun 14, 2002
mohawkboom's Avatar
Fuse as close to the battery as possible. generally within 12 inches of the battery.
Cheers
Mohawk
Old Jun 14, 2002
slikor's Avatar
slikor is an unknown quantity at this point
ditto what mohawk said. if you get an Amp Wiring Kit they usually come with a fuse holder attached on the power cable at most 12 inches from the battery. i got one from Scosche that had the fuse like 8 inches away from the battery [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
btw, the reason for the fuse being as close to the battery as possible is so that if something goes awry, the very first thing that happens is that the fuse blows, so nothing else has a chance to get messed up before the fuse goes. whereas if your only fuse on your power cable for your amp(s) was between your cap and your amp, you could have many other systems blown by the time your fuse gets fried.
Old Jun 15, 2002
microdot's Avatar
microdot is an unknown quantity at this point
I mounted my fuse on the side of the battery casing.
Old Jun 15, 2002
mohawkboom's Avatar
Quote
[hr]Originally posted by: microdot
I mounted my fuse on the side of the battery casing.[hr]
Please tell me you didn't use screws I've seen this done..
Old Jun 15, 2002
microdot's Avatar
I did use screws, but I didnt screw them into the battery. The battery has a black shroud surrounding it. I took it off, put the fuseholder onto it, an put it back over the battery.
Old Jun 17, 2002
CIVIC9782's Avatar
CIVIC9782 is an unknown quantity at this point
why did you do that ?
Old Jun 17, 2002
GoCivicRacerGo's Avatar
GoCivicRacerGo is an unknown quantity at this point
I didn't think it was necessary to mount the fuse holder to anything because it was already light enough. I just made sure to tape off all the joints with electrical tape to prevent any leaks.
Old Jun 17, 2002
HippyCivicEX012's Avatar
HippyCivicEX012 is an unknown quantity at this point
My fuse holder was rubber so i just laft it, it also only held one fuse for the one amp
Old Jun 17, 2002
microdot's Avatar
I have an ANL style fuseholder. It is best to mount those. They are larger than the fuseholders that come with most amplifier wiring kits.
zerochance
Sep 28, 2013 09:17 PM
ibanez6686
Lighting
Jun 8, 2011 08:19 AM
FurBall
Sep 6, 2005 03:37 PM
