Remote Wire help
Old Jun 7, 2002
microdot's Avatar
microdot is an unknown quantity at this point
Remote Wire help
Where do I run the remote wire when I have the factory deck. I read it was to the power wire of the deck. What is the easiest way to locate the wire?
Old Jun 7, 2002
WhiteRabbit's Avatar
i forget teh color of this wiree, but its teh ACC wire, the wire that is only a +12 source when teh key is in teh ignition. you want to tap into this wire and run it to wherever your amps are.
I also reccommend you throw a switch in there, otherwise your amp will be on as long as the car is on.
a good way to test before you run your wires is to have the amp sitting in your lap, then conect your remote wire. the amp should remain off. then put teh key in, the amp should turn on. thats how you know you got teh right wire.
Old Jun 7, 2002
microdot's Avatar
Will I have to take my deck out or can I locate it from under the dash. Also cant I just use regular speaker wire for the remote?
Old Jun 7, 2002
you can use very small wire for the remote if you like..... but youll have to take your deck out, unless you wanna fish around your steering colum looking for the ignition wire [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Jun 7, 2002
Ben's Avatar
Ben
Ben is an unknown quantity at this point
Can't he just tap into the cig ligther wire. that's easy to get at. its not constant.
Old Jun 8, 2002
oh yeah! forgot about that one....
Old Jun 9, 2002
microdot's Avatar
That is what I did. I ran two remote wires (one for each amp) from the cigarette lighter wires. I also put two switches into that console that houses the cigarette lighter. Should have my system done wiht pics by this friday.
SimpleUser
Apr 24, 2021 02:54 AM
mrwhos
Aug 11, 2015 02:03 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
