Need some amp help please!!! quick!!
Old Jun 6, 2002
Canter69's Avatar
Canter69 is an unknown quantity at this point
ok, i just recently got a kicker 440.1 mono class d amp. i also have a RF 200.2 amp going to the rear deck. The kicker amp is going to a 12" kicker comp vr (2 ohm dvc). i have the sub ran in a series making the sub 4 ohm. My system rocks, but every once in a while a song will come on or a bass line will hit and the amp cuts off. i have 4 guage power ran all the way to the back then splits and goes into each amp with 8 guage. the same with the ground 8 guage comes out of the amps and then into a block and is grounded with 4 guage. What is causeing this amp to cut off, insufficent ground or what????? [IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old Jun 6, 2002
mohawkboom's Avatar
Probably your ground. Also...check how hot the amp is when it cuts out....
Cheers
Mohawk
Old Jun 6, 2002
Canter69's Avatar
i check the amp and it is never, that hot. what would you recommend for the ground?
Old Jun 6, 2002
mohawkboom's Avatar
well nothing beats drilling a small hole in the trunk floor and stripping a square inch of paint off and bolting the wire on with a terminal.
But the seat bolt is plenty adequate..
Cheers
Mohawk
Old Jun 7, 2002
WhiteRabbit's Avatar
could be protection for teh amp. possibly a clipped signal? or maybe your asking too much of teh amp, try checking the load with a DMM, might be less than 4 ohms....
sounds to me like its a protection problem resulting from trying to draw too much current from the amp... check your impedances...
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
ricer_em2
May 11, 2016 08:09 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
metalpres
Sep 23, 2015 05:22 AM
