Indicator/headlight issues CIVIC EP3 (europe)
Front Indicators stay on(do not flash just solidly on) when my headlights are on and also my full beams don't work!!
I have a prefacelift car and facelift headlights.
All fuses and grounds are fine the lights are LED (so can't be the bulbs) so I am completely stumped here.
Any ideas??
Any ideas??
re: Indicator/headlight issues CIVIC EP3 (europe)
I did not install them therefore no idea, this was all done by previous owner
However when the indicators are on they flash as if a bulb was out so I would say probably not
the blinkers need a inline resistor to work. Common mistake
high beams, I think EP3 used a single bulb for low/high.
I don't think there are LED with low/high
Ahh ok, it is strange because they did work fine at first when I bought the car but after a while the full beams went, the electrical load detector went and since then my indicators stay on.
Fixed the load detector but same issue with the lights, I did have some wiring faults but I have since rectified them.
My headlights have 2 separate LEDs so I presume that 1 is for high and 1 is for low
jakeconnor
General 8th & 9th Gen
Oct 19, 2021 09:36 AM
Eikichi
Bolt-on Engine Performance
Aug 3, 2004 03:24 PM
