Where should i wire my amp too?
Old May 25, 2002
PrYnCeQT's Avatar
PrYnCeQT is an unknown quantity at this point
i have an sub in my trunk and the amp has 3 lines, battery, ground and a remote i believe its called, where should i hook the remote too? it was going straight to my battery before but i notice that when the car is off the amp stays on and i don't want it that way and its killing my battery. where can i hook up too? thanks
Old May 25, 2002
silver2k2civic's Avatar
silver2k2civic is an unknown quantity at this point
your deck (head unit) should have a remote wire on it unless it's stock.(this is the best because then it's only on when you have your stereo on)
If you don't have one of those you can wire it to your ignition ( then it will turn off when you turn the car off),
or you can wire it to a switch (just make sure you remember to turn off the switch)[IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old May 25, 2002
PrYnCeQT's Avatar
no idea where the ignition line is.
Old May 26, 2002
If you take off the panel under your steering colom you should find a fuse box.
look on the cover for the fuse box for the "ign" or the "alt" .
Then pull one or the other (make sure you remember where you pulled itr from)
then just connect a wire to ONE side if the fuse and then stick the fuse back in the slot.
when you connect the other end of the wire to the "rem" on your amp and turn on the car it should work.
[IMG]i/expressions/beer_yum.gif[/IMG]
Old May 26, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
No offense to silver, but hooking a wire to the fuse by wrapping it around the pin and pushing it back in is not the most professional way to go. I have had to fix many cars that had intermittant problems because the wires pushed the contacts away inside the fuse box. Plus it looks as if you were in a hurry.
The right way is to either hook it up to the remote wire, or hook it up to the radio's acessory wire. The easiest way is to remove the area around cigarette lighter and connect it to that wire.
Peace
Old May 26, 2002
ASWZero's Avatar
ASWZero is an unknown quantity at this point
The remote wire should be blue(if you bought and actual remote wire). Its blue for a reason. The remote wire is blue on the radio harness.
Old May 26, 2002
InspectaDeck's Avatar
InspectaDeck is an unknown quantity at this point
if you dont even know where your remote wire is you should just have someone else do it. cuz you're gonna mess it up, probably run your power wire along with your audio cables and cause a buzz in your speakers. just take it in. costs like 20 bucks, save yourself some uneeded confusion.
Old May 26, 2002
zero's Avatar
zero is an unknown quantity at this point
Do not put the remote wire at one end of the fuse and put it back in!!!!!! You can ""FRY"""" your amp, how do I know? Cuz I did that in my earlier installation from what my dumb anus friend told me to do. Fried my 300 buck amp....
Old May 26, 2002
armageddon's Avatar
armageddon is an unknown quantity at this point
I got two things...
#1- A WIRE STRAIGHT TO FUSE IS IGNORANT (no offence). IF you have an aftermarket HU use the remote wire on that and if you have a stock HU wire it to a switch. It looks better and you wont chance frying something.
#2- WRONG FORUM, use the ICE forum for "In Car Entertainmant" questions!! If you did a search in ICE you would have probably found an answer to your question.
Old May 27, 2002
sorry guys you'r totally right I havent done that since i was in highschool on my first system. I guess I wasn't really thinking.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old May 27, 2002
PrYnCeQT's Avatar
<< sorry guys you'r totally right I havent done that since i was in highschool on my first system. I guess I wasn't really thinking.[IMG]i/expressions/face-icon-small-confused.gif[/IMG] >>
good thing i didn't have time to check my thread early or i would have tried your way. i'll do the lighter one. sounds the easiest. and it is stock.
Old May 28, 2002
2K1SilverHX's Avatar
2K1SilverHX is an unknown quantity at this point
Use the stock turn on wire from the stock deck.... Look at the audio wiring diagram under the DIY link at the top of the page.... Hope it helps
sch2cm
Jul 21, 2015 09:58 PM
Civic65
Jul 19, 2015 10:13 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
robbie374
Jul 7, 2015 02:56 AM
