Remote start/unlock/lock
Old Sep 7, 2019
Mojo20032004's Avatar
Mojo20032004 is an unknown quantity at this point
So got my remote start installed. Got that to work. Hooked up the 2 wires for lock/unlock and the doors are not responding. But clicking on the oem remote it works fine as long as the car is turned off. Do I need to purchase a external lock/unlock module for the system to work properly? This is for a 05 Honda civic coupe.
Old Sep 7, 2019
GolNat's Avatar
Prelude Owner
Re: Remote start/unlock/lock
Most aftrermarket systems have an option for (-) trigger or (+) trigger. Do you have it set to the correct one?
Old Sep 7, 2019
Yes I do. I know the honda door locks/unlocks use (-), and I hooked it up per instructions but nothing is happening. The lights flash as it got the command, but the actual actuator doesn't do anything
Old Sep 7, 2019
GolNat's Avatar
Prelude Owner
Do you a meter or test light that you can use to verify the signal is coming out of the module?
If you have the correct signal (which you do) and it is connected to the correct wires it should work.
What system are you using? Brand, model
Old Sep 8, 2019
Yes I have a meter, I will try that out tomorrow. Model is a crime stopper sp502 which is a 2 way system
Old Sep 8, 2019
GolNat's Avatar
Prelude Owner
Car color code:
Unlock: WHITE/ GREEN (-) @ Gray connector above drivers kick
Lock: WHITE/ BLUE (-) @ Gray connector above drivers kick
Old Sep 8, 2019
Car color code:
Correct, that's how I have it.
Now lf trigger and rf trigger are those for the actuators?
Old Sep 8, 2019
Car color code:
Gene Clark
Exterior
Apr 14, 2019 03:40 PM
Rawr.monsters
Feb 28, 2016 11:05 AM
cicero36
Oct 24, 2014 09:10 PM
MookyStick
Jul 28, 2012 06:34 PM
bmnot
Jul 25, 2011 03:42 PM
