Getting power to the rear?
Old May 22, 2002
mdonohoe's Avatar
mdonohoe is an unknown quantity at this point
Hi Guys,
Done my last car with a pretty decent setup, doin up the civic the same, sedan 2001 model 1.7l no vtec etc etc. Aussie model, but seems to be 100% the same as the yank model.
How'd you guys get your power to the rear? I'm usin amps and I always use large cabling(read 4 gauge) got all my battery connectors and stuff and insulators and dist blocks & fuses.. Where should I put it through the firewall?
I've found like a possible point behind two hoses and one of the aircon hoses seems to run very close to it.. it's plastic/rubber and I can push on it a fair bit and all it seems to do is flex like a baloon?
in my old telstar there was a thing like that and i cut it with a pocket knife and put my 4ga straight through to the rear...
let me know...
Old May 22, 2002
toastyghosty's Avatar
toastyghosty is an unknown quantity at this point
passenger footwell peel back the carpet and you'll see the rubber grommet in the floor where the wires come through the firewall...looking from the engine bay it's just under the intake resonator....you'll probably need to x-acto knife the grommet slightly to make it larger for your 4g to fit through..
once through you can run it under the door sills and to the back...
Old May 22, 2002
mdonohoe's Avatar
Aussie model here or U.S model?
Aussie model's are RH Drive so we may be talking about the same thing, is yours a bit hard to access(Ie requires a bit of hand work to get into where it is?)
Old May 22, 2002
WD40's Avatar
WD40 is an unknown quantity at this point
4 Guage? Geez, that's thick. Anyway...
Underneath the resonator there is a hose that runs through a rubber seal in the firewall. I just punched a hole in that seal and ran my power cable through there.
As far as inside the car, I pulled all the plastic panels off the side and ran the cable under the plastic on the passenger's side door jamb, behind the plastic side wall and into the trunk. Rather time consuming, but all in all it's a nice installation.
Old May 23, 2002
oops sorry didn't notice you were aussie...
mine would be the north american model so left hand drive....
should be same though under the carpeting and under/behind the resonator in your engine bay...
7thgensurvivor
38
Aug 29, 2015 11:50 AM
MamaBear2015
Jun 11, 2015 07:33 PM
Mercilus
Jun 7, 2015 10:00 PM
Lopes101
Jun 7, 2015 08:04 PM
PimpBot5000
Nov 26, 2001 07:15 PM
