01 civic cluster problem
Old Jul 10, 2017
mike96gtvert's Avatar
mike96gtvert is an unknown quantity at this point
Question 01 civic cluster problem
My MPH on my cluster is not working, it gets stuck and doesnt move like normal.
i have an 01 civic ex.
what clusters work and fit? will a new cluster work? im not sure. :/
thank you in advance.
Old Jul 10, 2017
Re: 01 civic cluster problem
If you want a straight up replacement, you'll need one from a car that matches yours.
There's a couple threads in this forum about cluster swaps, use the search bar.
Old Jul 11, 2017
no other years will match?
Old Jul 11, 2017
For 2001 alone, I just saw about 22 different possible choices in the parts catalog, only one of which is exactly correct for any particular version of the car according to Honda.
Swaps from other cars are possible though there may be issues if you pick a version that isn't exactly compatible.
For more info, search for the threads about cluster swaps.
Old Jul 12, 2017
how do i ensure i swap for the exact one I need?
Old Jul 12, 2017
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
This link will do what you need.
http://bfy.tw/Cnho
Old Jul 12, 2017
that link will prove your an idiot.
Old Jul 12, 2017
*you're
Old Jul 12, 2017
Various swap threads, but it might be pretty involved trying to convert wiring to make older car work with a newer cluster.
https://www.civicforums.com/forums/1...faq-video.html
https://www.civicforums.com/forums/1...er-models.html
https://www.civicforums.com/forums/4...-pictures.html
Again: If you want a straight simple swap, the donor car must match yours--year, trim level, transmission, SRS components....maybe more.
Old Jul 13, 2017
CraigW's Avatar
Pull the cluster and look for part ## sticker.
