ECU SWap
Old Sep 29, 2016
shawn101's Avatar
shawn101 is an unknown quantity at this point
ECU SWap
hi every one
just have a question if some one can help me in right direction i have 2 door 04 civic lx manual and ecu is toast because of mice ate all wiring so my question is will any year 01-05 civic manual ecu/immobilizer with key will work with my civic or is it only specific 04 lx thanks in advance for helping.
Old Sep 29, 2016
shawn101's Avatar
Re: ECU SWap
bump
Old Sep 29, 2016
Re: ECU SWap
has to be 04-05,
non-vtec same as your engine,
and manual trans same as your trans
and it has to be programmed (immobilizer) before the engine will run, or you have to get the matching immobi system and steering lock and keys from the donor car.
Make sure all your wiring is fixed so you don't burn up another control unit.
Old Sep 29, 2016
shawn101's Avatar
Re: ECU SWap
Originally Posted by ezone
has to be 04-05,
great thank you so i have no choice i have to find the right ecu. i dont know if dealer will programmed old ecu will find out thanks
Old Sep 29, 2016
Re: ECU SWap
Absolutely.
I did not look to see if there are more differences between California emissions and the other choices, either.
Your local salvage yards part interchange books may have more info.
I'm sure they will want your money.
Old Sep 29, 2016
shawn101's Avatar
Re: ECU SWap
will the 4 door ecu work or is it different?
Absolutely.
Old Sep 29, 2016
Colin42's Avatar
Re: ECU SWap
4 door should be fine
Old Sep 29, 2016
Re: ECU SWap
Coupe or sedan, no difference
fishklr1
Jul 12, 2016 11:56 AM
Zealot Prime
May 26, 2016 06:29 PM
AddictionJDM
Engine Swaps
Apr 2, 2016 09:36 PM
dsm482
non-VTEC to VTEC Head swap
Mar 29, 2016 04:39 PM
whiteek
Feb 26, 2016 10:04 PM
