2003 civic brake light/socket
I bought this car to get me around to school, work, & home.. the ONLY downfall was that is was missing the rear brake light sockets....no problem I found them online and ordered them.
Car was running fine UNTIL I installed the brake light and sockets ....AND THEM NOTHING, car does not start.
There is a clicking noise on the fuse box, the one out on the hood next to the battery. When I turn the ignition key to start car ...the noise dims but nothing else. Noise would not stop so I took one the clamps off from the battery.
ANYONE HAS HAD A RUN-IN WITH THIS ISSUE & HOW YOU SOLVED IT?
Your advice would really help me solve this problem.
Re: 2003 civic brake light/socket
i would start by undoing what you did and get the car running again. It sounds like your grounding out the socket but I can't imagine that stopping the car from starting unless you blew a fuse. But even then I would think the car would still start.
If the car was missing the brake light sockets then I would imagine the original owner probably messed with the wiring. I'd check around the truck for anything obvious and also check under the dash for some spliced wires.
mgcivicdriver
Engine start problems
16
Dec 10, 2015 11:58 PM
Youngrob650
Nov 12, 2015 11:01 PM
R Steele
Oct 22, 2015 05:09 AM
