CPM code Circuit A or Bank 1 car wont start.
Old Jun 15, 2016
AlexFromCali's Avatar
AlexFromCali is an unknown quantity at this point
I recently changed my fuel pump, but I had to use starter fluid down my intake to start it.
It ran fine for 5 whole minutes, meaning the fuel pump was fine. I changed the pump with literally no gas in the system. And filled it when I was done.
However, I had a CPM code before I did it, and the engine ran fine. However I did backfire out my straight pipe if I didn't let fuel pressure build up on ON first.
After changing the fuel pump, and starting it for 5 minutes (CPM sensor wire was disconnected because I was stupid)
I reconnected the CPM sensor wire harness to the new sensor and it doesn't start.
The check engine like for the CPM code comes on, although resetting ecu and battery. I still haven't IDLE RELEARNED.
The questions:
- Does the crank have to be TDC to start the car? Timing isn't off since it was done.
- How do I check to see if the wiring harness is functioning, I doubt the new OEM sensor is bad
- Anything else?
When I was driving the car on the CPM code i would be rev limited at 3.2k rpm.
Old Jun 15, 2016
Colin42's Avatar
Re: CPM code Circuit A or Bank 1 car wont start.
No
Check continuity, verify you have correct voltage
Old Jun 15, 2016
Delete thread problem is the fuel pump strainer. It's brand new so I'm stumped as to why it's not doing its job
mgcivicdriver
Engine start problems
16
Dec 10, 2015 11:58 PM
steve6
Nov 22, 2015 08:18 PM
TheBhoyJay
Nov 20, 2015 08:47 AM
R Steele
Oct 22, 2015 05:09 AM
AnotherDopeStyle
Nov 1, 2001 01:58 PM
