Intermittent high beams
Old Mar 26, 2016
Brad.s19's Avatar
Brad.s19 is an unknown quantity at this point
2005 coupe ex special edition 1.7
Intermittent high beams they work when they want.
Dash indicator does not function when lights are not.
Functions when they are.
Ohm'ed the red/blue 1Ohm
Have source voltage power and ground at the connector
Wiggle tested all the lines
looked for points of chaffed/damaged wire
If I pull either 15/17 20a mini blade the side connected functions but no dash light indicator
Ohm'ed the relay's low side 90 ohms activates when powered for both
Leaning towards the multifunction switch.
I only have a basic digram and no specs just been shooting for under .5 Ohms and source voltage.
Old Mar 26, 2016
CraigW's Avatar
Re: Intermittent high beams
I would say look at what resistance, or voltage that pin4 (BLU/RED) is at when the problem occurs.
Near 0 ohms (lights off) & near 0 volts ( lights on) when grounding path complete and high beams working
Flash feature work ??
Emosteevo
Mar 24, 2017 03:51 AM
Poopies
Lighting DIY
20
Dec 16, 2015 10:10 PM
jimmyfloyd
Nov 21, 2015 11:10 AM
redrocket87
Nov 1, 2015 07:15 PM
CraigW
Oct 13, 2015 08:56 AM
