MCU Compatibility
Old Dec 5, 2015
downtoclown's Avatar
downtoclown is an unknown quantity at this point
MCU Compatibility
Anyone know if a '04 mcu would be compatible with a '02? Or how to find out?
Old Dec 5, 2015
Re: MCU Compatibility
Nope nope nope!
01-03 use O2 sensor, 04-05 use AF sensor. NOT swappable.
Old Dec 5, 2015
Darn, thanks.
Old Dec 6, 2015
Any chance I could use it to troubleshoot my gauge cluster? Speedo, tach, fuel gauge, etc. don't work and I'm trying to figure out why. It'd be nice to know if the mcu was the culprit. Or rule something out at least...
Old Dec 6, 2015
Wait a minute....What are you calling the MCU? The motor control unit (PCM, ECM, ECU) or the multiplex control unit (MICU)?
Old Dec 6, 2015
Do a cluster self diagnosis first. That would make the needles all sweep and lights flash.
If a PCM burns up the gauges usually act weird, not die altogether. PCM burns up when someone leaves the alternator mounting bolts loose.
If an MICU dies there are usually many other weird electrical symptoms to go along with it: AC, locks, dome lights, warning beeper are usually all affected by an MICU failure.
The most recent one I replaced had the red BRAKE warning light stuck on on the dash.
Old Dec 6, 2015
CraigW's Avatar
Those clusters have a huge PCB themselves.....and early ones are known to give problems.
Same with early MICUs on 7ths.
Old Dec 6, 2015
The multiplexer, so MICU I guess. Ido have some other strange problems but mostly related to the cluster. It's intermittent though. When the cluster goes off, the brake light stays on. Also the backlight for the ac controls goes out. I have a spare MICU from a '04 and one from a '02 automatic (mine's a manual) that I pulled from the junkyard. Just was hoping to be able to test something before I go spend on a new cluster.
Old Dec 6, 2015
Well that explains it better. Still not exactly compatible.
According to the parts catalog numbers, they all have different part numbers....but might be worth plugging in just to see.
DX vs. EX/LX
Auto vs. manual
Coupe vs. sedan
There's 8 different units right there.
and each year picked adds even more part numbers to those. 02 and 04 gave me a total of 16 different part numbers and I did not look at the hatchback choices.
CoupeGuy04
Apr 12, 2016 01:29 PM
Marc23.4
Dec 12, 2015 05:45 PM
MamaBear2015
Dec 5, 2015 04:03 PM
greenbean209
Suspension
Oct 28, 2015 09:17 AM
