Gauges not working, '01 EX 2dr, please help....
Old Sep 17, 2013
CFDBattChief's Avatar
CFDBattChief is an unknown quantity at this point
Post Gauges not working, '01 EX 2dr, please help....
My son has a 2001 EX 2dr 5-speed, and none of the gauges on the instrument cluster are working. I have pulled it out, checked the connections, the PCB doesn't seem to be fried anywhere, and all fuses are good. The odometer does not display, either. All of the idiot lights work. It just seems that the gauges have no power.
Have priced online a new one, around $250. Plus, around $99 to get the odo to match the old one.
The one place I had hopes of being able to repair it, now says that they cannot repair it.
Have looked online and called places locally, and so far no one has a used one for this particular model.
I am looking for some advice or suggestions on how to get it repaired or replaced. Any help would be deeply appreciated.
CFDBattChief
Old Sep 17, 2013
Re: Gauges not working, '01 EX 2dr, please help....
If you have all of the lights but no gauge action, it's probably going to need a cluster.
www.car-part.com
There are other options, like do a swap from a different Civic. More work is involved if you go past certain years. https://www.civicforums.com/forums/1...faq-video.html
Old Sep 18, 2013
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
  • Yeah, I wish I had a latter instrument cluster. It seems like it's much easier to read.
Old Sep 18, 2013
Ok, ezone and Matt_75, thank you. When I have checked on a used one, the things that seemed to be important was:
Year, model, body style, transmission type, and whether or not it had side impact air bags. As far as further searching for a used one, can someone tell me if in fact all of these characteristics matter? Some are obvious, like the transmission type (tach or not), but the others are questionable. In other words, if my son's is an '01 2dr EX 5-spd w/o air bags, is it important that I find one that matches these criteria?
CFDBattChief
Old Sep 18, 2013
I can't really answer for certain, I deal with strictly original stuff at work.
Read through the thread dealing with the swaps.
I pretty dang sure that if the car has side airbags and OPDS in the passenger seat, you need the "side airbag off" light in the cluster or else there may be SRS codes set if that light is missing.
But if the car does not have those side airbags......the SABoff light may still come on...? Dangit. I can't remember.
Um, I think for a long time we had a brand new cluster that we couldn't send back because someone picked the wrong choice (out of maybe 23 possible choices) and one of these scenarios came up.
I think you can put a manual cluster in an automatic car, you just won't have the PRNDL lights.
The rest of the stuff, I really don't even want to guess.
Old Sep 18, 2013
Try resoldering all the pin terminals on the board where the wire harnesses connect to the cluster?
Old Sep 19, 2013
lito99's Avatar
lito99 is an unknown quantity at this point
I can vouch that ABS and side srs matters, If you have side srs then preferably find a cluster with it. If you get a cluster without tht light youll be ok, you just wont have that particular light but it will still function. All EX models have ABS so you"ll be looking for that too, but again it will work even if the cluster has no ABS light. I replaced my cluster with one that has no ABS and works fine.
Can you figure out if yours has side srs?
Old Sep 19, 2013
The car does have SRS in the steering wheel, but apparently what matters as far as a gauge cluster is if it has side impact SRS in the seats. From what I have been able to gather, some models had side SRS and some did not. My son's car does NOT have side SRS, is a 5-speed, 2dr, '01 EX.
CFDBattChief
Old Sep 19, 2013
They all have front airbags. One for driver, one for passenger.
Correct.
There would be a label sewn into the upper seatback, plainly visible.
Random image of one, not from a Honda but you get the idea
Correct
A VIN entered on many parts websites would eliminate most incorrect choices if you need an original part number for a correct cluster.
CFDBattChief
Bruce.Ringler
Jun 18, 2015 08:12 AM
Ma213802
May 18, 2015 07:01 AM
werdnahall
May 17, 2015 11:37 AM
ORskier
May 3, 2015 12:54 PM
tylerginevan
Apr 27, 2015 12:29 PM
