Car Stereo Install 2001 Civic LX Sedan
Old Mar 26, 2013
kevin707's Avatar
kevin707 is an unknown quantity at this point
New to Civic's just bought one two weeks ago. I also bought:
-a kicker amp
-4 speakers (coaxial polks) 6.5's for front & 5 1/4's for back
-Kenwood Head unit
-a 1.2 Ferad cap
- a 10" sub (kicker) (also have a 15" jbl available but does not fit that well)
The questions I had were (obviously estimates)
1) How long would it take to install *note* (doing it with a friend who has a decent amount of experience in car installations just not familiar with Honda)
2) What mounting brackets are needed
3) Amount of speaker wire needed. (Planning on putting the amp under either passenger or driver seat, sub in trunk, speakers and sub driven by amp)
4) Any tips or suggestions?
Any relevant input would be great!
Thanks.
Old Mar 26, 2013
sl33pyriceboi's Avatar
Re: Car Stereo Install 2001 Civic LX Sedan
1. it will take you a good 5 hours with both of you. he knows the fundimental basics but i doubt he'll know the civic well. he will have to find routes and such to wire it.
you'll need to take out door panels, rear panels, run speaker wire, take the head unit apart, wire and run the power wires through....etc.
2. you might need 1" spacers in the front depending on how deep your front speakers are. your sedan uses 6.5" speakers all around. so you will have to modify your rear to fit them with proper spacers and such.
3. if you are running a double wire (has both + and -), you will need at least around 50ft of speaker wire. you will need about 10ft of power wire (no less than an 8 awg). 4awg is a good compromise between cost and power...
4. post picts. go look at the DIY for the headunit removal. keep us updated.
post questions on here. you can email me if you want a faster response (or just email to notify you need a response on the forum. sl33pyriceboi@gmail.com
Old Mar 26, 2013
kevin707's Avatar
Thank you for the speedy response sl33py, I appreciate it. I will definitely post some pictures most likely before and after shots. Will let you know if I have any more questions as the project proceeds.
Old Mar 26, 2013
Kennykid2002's Avatar
Kenny the Ricer
The amp install should take no longer than an hour.
Speaker install, at most 2 hours for all 4
Headunit is where it's going to kick you in the ***.
It can go anywhere from an hour up.
Take your time, do your research, get it right the first time.
You do not want to take stuff back apart because you messed up.
Buy quality wires. Cheap ebay wires will trick you by using overall diameter for gauge sizes, rather than the gauge size of the wire.
You might purchase a 2GA wire, but only having a 8GA core. with massive amounts of plastic shielding.
Old Mar 27, 2013
kevin707's Avatar
We had to work on it for a long time yesterday, took us awhile to pull off all the parts but everything will be hidden and its looking and sounding great so far!
mattdoc
Mar 14, 2017 12:10 PM
usajags84
May 10, 2015 08:11 AM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
liljoe
Nov 4, 2001 01:27 PM
