all speakers stopped working !! please help
Old Mar 23, 2013
ricerflyby's Avatar
ricerflyby is an unknown quantity at this point
Exclamation all speakers stopped working !! please help
NEED HELP W/ ALL SPEAKERS PLEASE
So i ripped the panels off my 04' civic thinking this would be a 20 min. process. Nope. After i got the door panels off (just the front 2 door speakers) then i had to pry off the factory door speakers(didnt know this was normal btw) and found out I had to just drill mine into the metal somewhere i could. tiiiiight. so after searching for someone w/ a drill and drilling my holes to mount my speakers, I finally get them wired in & mounted, and start up the civic. The only thing that works is the subs, they go along with the beat & all. My amp is good, obviously, but ALL of my door speakers stopped working. Now there's a few things im going to go try after i post this----1] on the driver side speaker i possibly could have switched the wires----2]unconnect battery for like a 1/2 hour and then go reconnect & try again. ANY HELP WOULD BE APPRECIATED GREATLY, FOR REAL SON.
Last edited by ricerflyby; Mar 23, 2013 at 10:10 PM. Reason: wanted to thank anyone for trying to help, this been wrecking my brain all day
Old Mar 23, 2013
Re: all speakers stopped working !! please help
Speaker wiring shorted to body ground could kill all outputs, so might a plain short in a pair of speaker wires.
Go back to each speaker you messed with.
Check if you got a wire pinched.
Disconnect one and try the radio. If it makes noise again, then that speaker was shorted. Try the next one.
HTH
Old Mar 23, 2013
ricerflyby's Avatar
allright I'm on my way to go try that right now. thanks for the quick reply mane. i should work @ the Hona assembly plant, the # of times I've taken these apart and put them back together. Also, I'm not sure if you know this but there isnt much room in the speaker "hole" i guess because you have to make it. you basically tear the old speakers out & then make a pair of 6.5"s work. do you think the magnet on my 6.5"s touching metal could possibly cause any problems? thanks
i <3 hoNda
Old Mar 23, 2013
Magnet won't, that would just make them buzz or something, not kill the output from the radio
Old Mar 26, 2013
Therdest's Avatar
Therdest is an unknown quantity at this point
Go back to each
buy speakers you messed with.
HTH
Yes it seems to be problem caused by shorted wire. You need to check it deeply as it can cause complete speaker damage.
Old Mar 26, 2013
CraigW's Avatar
If the speakers are twisted even slightly they will short and protection on amp kicks in.
crowtoo
May 11, 2015 06:50 PM
ORskier
May 3, 2015 12:54 PM
ashleymmackey
Apr 18, 2015 09:48 PM
CivicLX2001
Nov 16, 2001 06:33 PM
