Vent controls dont work
Old Mar 6, 2013
allturbo98's Avatar
allturbo98 is an unknown quantity at this point
Ok, just as the title says. My vent controls do not work. Right now they are stuck on the face vent and will not change to any other setting. Ive checked the #14 fuse under steering column and it was good. Is there any thing else that could be causing this?
2004 Civic VP
Old Mar 6, 2013
Re: Vent controls dont work
You have an actuator that moves linkages, and a dash controller that powers the actuator.
Any part of it can be a problem.
You will need to do some investigation and logical thinking to figure it out.
Does the actuator move?
Is the linkage binding?
Is the control unit trying to power the actuator?
Then some testing to determine WHY.
A wiring diagram, a voltmeter, a service manual.....
Or play swaptronics if you have another car to rob parts from.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
crowtoo
May 11, 2015 06:50 PM
ORskier
May 3, 2015 12:54 PM
cooldan1
Apr 23, 2015 10:49 AM
Microbiology
Nov 9, 2001 10:10 PM
