In search of HO Alternator
Old Mar 6, 2013
rta60460's Avatar
rta60460 is an unknown quantity at this point
I'm looking for a high output alternator for my 01 ex sedan that will bolt right in without having to modify anything, I also plan on bypassing the eld to keep my voltage up...I'm gonna be running a 3,000 watt system so the alt needs to be a decent one.. Can anyone point me in the right direction? Thanks
Old Mar 6, 2013
danwat12345's Avatar
danwat12345 has a spectacular aura aboutdanwat12345 has a spectacular aura about
Re: In search of HO Alternator
Yup with my 6th gen I unplugged the ELD with no problems and voltage stayed at ~14.2 to 13.8V with most situations. I bought a 165A alternator for $125 shipped on ebay back in 2010 and it still works fine today after some abuse. Gets nice and loud like an electric motor on a hybrid car when I stress it. Cost another $100 to have it installed.
Assuming most (cheaply) rebuilt alternators have similar characteristics,
The voltage sags down to a consistent ~13.2V when you put about 2000 watts of load on it which is fine for me, it's delivering it's rated amps more or less.
It doesn't cool itself well enough when maxed out, it starts smelling after a few minutes so yours probably will to unless you keep it at high RPMs. Might want to go for a big body alternator if that's possible.
Make sure what you get has a decent warranty and buy a cigarette lighter volt meter.
http://www.ebay.com/itm/Honda-Civic-...d46bb9&vxp=mtr
EDIT: also, try to find an alternator that has a fan thing on the pulley so that it can cool itself better than the cheaper ones like the one I got
Old Mar 6, 2013
BlueEM2's Avatar
Whachya lookin at?
How did you unplug the ELD?
Old Mar 6, 2013
On a 6th gen anyway it's in the main fuse box under the hood under a few big fuses in the front. I think you take those out so you can take out the brown colored ELD module.
I think Canadian models come with it removed because of the colder weather
Old Mar 6, 2013
BlueEM2's Avatar
Whachya lookin at?
I have a 7th gen I don't think it's so simple. I'm going to check and see if I have one I never actually looked and have never heard of the Canadian thing
Old Mar 7, 2013
I think this is a 7th gen
and the following video turns out I made a while back for my 6th gen, watch from 12 minutes onward for a few minutes.
A couple things you might want to look out for; Cheapo rebuilt alternators like the 1 I got, it's not a big body, the pulley isn't any smaller than stock, and it doesn't have a fan blade on the pulley shaft. So, it would be a good idea to get those things if you plan on putting heavy continuous loads on the alternator. The rated amperage is definitely peak because the efficiency isn't that good, alternator will heat up. But for sound systems the peak is great for powering those bass notes.
WaryDriver
Aug 8, 2015 05:08 PM
viperGTS
Jul 27, 2015 08:40 PM
jzhartman
22
Jul 23, 2015 10:42 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
trellex
Electrical
Jul 9, 2015 12:01 PM
