I got wat i payed for
Old Jan 20, 2013
dugfrsh6901's Avatar
dugfrsh6901 is an unknown quantity at this point
well here is the deal i did not want to pay a pro to hook up my system so i had a buddy hook it up for free well for starters he cut my stock stero plug insted of buying a harness adapter kit and i have some problems with some of my dash lights and my brain stoped working[my cars brain] and was wondren if any dash lights or my brain tied into my stero plug please help me 2002 civic
Old Jan 20, 2013
BlueEM2's Avatar
Whachya lookin at?
Re: I got wat i payed for
Check for blown fuses. If there is a fuse blown its blown for a reason and you need to redo the install. Most likely he hooked up the illuminator wire which your not supposed to do on these cars because it fries things
Old Jan 20, 2013
CraigW's Avatar
Any head unit connections made to factory RED or RED/BLK should be isolated...and check called "small lights" fuse and without more info as to what else failed I would check the fuse outside called "back up"
Old Jan 20, 2013
SlimRisk's Avatar
Busy Speeding!!
SlimRisk is a jewel in the roughSlimRisk is a jewel in the roughSlimRisk is a jewel in the rough
This guy is the master with electrical systems on these cars ^^
carid
Sep 28, 2015 10:13 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
