Key fob and remote start
Old Jan 14, 2013
halln6's Avatar
halln6 is an unknown quantity at this point
I have an 03 EX that I got used with a remote start. My keys were stolen a week back, so now I need to replace the key fob. But I don't know how to find a replacement that will work with the remote start. The thing is... I don't know what brand model it is (installed by the previous owner).
Any one know were I can look to find out?
Thanks for the help.
Old Jan 14, 2013
GolNat's Avatar
Prelude Owner
Re: Key fob and remote start
Pull the cover off from underneath the steering colume ( the one that allows you access to the fuse panel) and look for the control unit. When I put my remote start in I was able to fit it under there. If you can't find it remove the steering wheel cover and follow the wires that were cut into the ignition switch. There should be 2 boxes, a smaller one for the key bypass and a larger control unit for the remote start and keyless entry. Get the number off the larger control box and google it.
The control module should look something like this with large heavy gauge wire coming out of it:
Old Jan 14, 2013
Or take it to a local installer that deals with aftermarket electronics daily.
Most will either hook you up if it is a brand they sell/install, or direct you to whomever installs your product brand.
HTH
Civic2002lx
Oct 7, 2015 09:17 AM
Laurenhunter7
May 10, 2015 01:09 PM
MamaBear2015
May 3, 2015 02:17 PM
DaveyD
Mar 28, 2003 12:28 AM
loquito
Nov 12, 2001 07:24 PM
