Interior Lights
Old Dec 22, 2012
botakcivic's Avatar
botakcivic is an unknown quantity at this point
Interior Lights
This is gonna top the "dumpest" question for 2012 .
Subject: 2003 Civic EX Sedan
Are there any other interior lights beside the front reading and rear dome light?
No lights on cup holders, glove compartment and this light....
cant' think of the word, sorry...i think is call foot well light.
Thx in advance.
Old Dec 22, 2012
GolNat's Avatar
Prelude Owner
Re: Interior Lights
Correct. There are only the map lights and dome light. You can lights anywhere you want though b
Old Dec 22, 2012
botakcivic's Avatar
Re: Interior Lights
Cool. Appreciate it!
I'm assuming its fairly easy to add lighting huh?
Old Dec 22, 2012
GolNat's Avatar
Prelude Owner
Re: Interior Lights
Yea, its not hard (if you can do basic electronics). Just need to mount LED strips and run them to your interior light wire or a separate toggle.
Old Dec 23, 2012
botakcivic's Avatar
Re: Interior Lights
K. Thanks!
Happy Holidays!
Old Dec 24, 2012
Therdest's Avatar
Therdest is an unknown quantity at this point
Re: Interior Lights
Originally Posted by GolNat
Yea, its not hard (if you can do basic electronics). Just need to mount led bulbs strips and run them to your interior light wire or a separate toggle.
These led strips looks amazing. I will surely try them.
Old Dec 25, 2012
danwat12345's Avatar
danwat12345 has a spectacular aura aboutdanwat12345 has a spectacular aura about
Re: Interior Lights
Also remember CCFL, like what's in modded computer cases can work well too, they just take a minute or 2 to reach full brightness. Logisis is pretty affordable
Old Jan 14, 2013
NAcaRice's Avatar
Low `n` Slow
NAcaRice is an unknown quantity at this point
Re: Interior Lights
Does anyone know how to hook up those LED lights with a toggle? I don't know how to do mine
Old Jan 14, 2013
botakcivic's Avatar
Re: Interior Lights
This might help...
http://www.8thcivic.com/forums/inter...box-light.html
Old Jan 15, 2013
yagelbagel's Avatar
yagelbagel is an unknown quantity at this point
Re: Interior Lights
With mine I took the 12 Voltage source wire, screwed it on the off side of the toggle switch and connected the positive (hot) wire to the on side of the toggle switch, then just have the ground going to ground. Message me if you stilll need more
Old Jan 15, 2013
NAcaRice's Avatar
Low `n` Slow
Re: Interior Lights
Got it thanks! I actually did it a lot differently. I ran the power source wire from one side of the switch to the fuse of the 12V in the fuse box (jusr stripped the wire and wrapped it around the contact). Then I ran the power for the lights to the other side of the switch. And finally grounded it. Works perfect and I can still use my 12V outlet
Lopes101
Jun 7, 2015 08:04 PM
werdnahall
May 17, 2015 11:37 AM
Cross
Dec 9, 2001 05:53 PM
supercivic01
South
Nov 30, 2001 11:27 AM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
