What's wrong here?
Old May 3, 2002
SpacemanBob's Avatar
SpacemanBob is an unknown quantity at this point
What's wrong here?
OK so I got a 10" tube in my trunk, it's a sentrek. The thing rattles like all hell. Actually, it's more like a buzz, but it's when it hits, not a constant one. It's not coming out of the speaker, it's definately something rubbing. So here's my Qs:
1. Is there anything I can do to fix this?
2. What other cheap options are there; I don't listen to music that needs big bass (I listen to punk, ska, alternative, etc.), just want a sub for a little extra low-end support, ya know? So what else can I do that's cheap and will still let me hear the other parts real well?
Thanks!!
Old May 3, 2002
scrible's Avatar
scrible is an unknown quantity at this point
suggestion would be to match u a small 8 setup like maybe a JL 8" sub thats around 250watts total
put about 100w on it and it should give u a good sounding bass for your system
Old May 3, 2002
JSWhaler's Avatar
JSWhaler is an unknown quantity at this point
look around to see what is rattling, I would assume that it's coming from the rear deck, mine does since they're plastic on our cars. Move your hand around there to see if you can find out what is rattling. Try adding some foam or dynamat around there. Mine rattles and it probably will till I dynamat my entire trunk, best of luck.
Old May 4, 2002
I'm pretty sure it's actually a part of the tube that's rattling, but I'll check the rear deck
ricer_em2
May 11, 2016 08:09 PM
speedlever
Sep 24, 2015 07:18 PM
pilebuck13
Sep 21, 2015 10:45 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
