Hazards and Cluster Flash after HU Install
Old Apr 24, 2012
Drewh1991's Avatar
Drewh1991 is an unknown quantity at this point
I just got a 2001 Civic EX and installed a new head unit in it (Sony MEX-BT3000P) and now randomly the hazards and the cluster will flash in unison, and eventually stops. Does not seem to be connected with operation of the HU as messing with it doesn't really cause it. It usually happens when you start the car. Could this be me mis-wiring the HU? The previous owner also has an aftermarket security system installed which I can't seem to figure out. There is a switch that was installed next to the Cigarrette lighter. Flipping it doesn't seem to do anything. If anybody has any suggestions they would be much appreciated.
Old Apr 25, 2012
iridehonda's Avatar
iridehonda is an unknown quantity at this point
Re: Hazards and Cluster Flash after HU Install
Did you connect the orange wire? If so you got lucky because it usually fries the entire electrical system. Disconnect it.
Old Apr 28, 2012
Drewh1991's Avatar
Nope! Did not connect the dimmer or illumination wires, I did my homework. I figured out the problem, it was the aftermarket alarm. I just put it in valet mode and it stopped (had to go to manufacturers website). I do have a question about the ground wires though: should I use both the ground from the HU and the ground from the harness? Or just 1?
Old Apr 28, 2012
iridehonda's Avatar
I'm not entirely sure but I can't see having both connected causing any problems.
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
MamaBear2015
Jun 11, 2015 07:33 PM
steveneddy
May 19, 2015 02:39 PM
Fastfebur
Apr 22, 2015 01:37 PM
civic_gt
Apr 19, 2015 08:15 AM
