2004 Civic SE (Canadian) Keyless Entry Install (WORKING!)
Old Apr 21, 2012
vex_helix's Avatar
vex_helix is an unknown quantity at this point
Guys,
I got a keyless unit from a 2005 civic, but I don't have the harness. The harness on the 2005 civic seemed like it was all integrated into the big bundle with electrical tape. I didn't see it as a separate harness
Is it possible to hardwire this keyless unit to my 2004 civic se?
I have attached some pictures from my 2004 civic se and the keyless unit from 2005 civic.
Old Apr 23, 2012
vex_helix's Avatar
Re: 2004 Civic SE (Canadian) Keyless Entry Install (WORKING!)
Got this working!
I had a 2005 EX key receiver unit but it didn't work for some reason on my 04 SE. Maybe the receiver was bad or just not compatible.
Traded that for a 2001 EX key receiver and bingo!
For instructions on how to remove trim and get to wiring part:
http://www.handa-accessories.com/civic/05keyless.pdf
Wiring is straight forward. No need for Honda's pretty discontinued harness.
Here's the pin out connections:
1. Black = Ground (I connected it straight to the ground bolt)
2. Blue/Orange: You should have this wire already there connected to the accessory connector with blue tape. Remove tape and use!
3. Yellow = Ignition (cig lighter/accessory connector yellow)
4. empty
5. White/Red = constant power (I tapped the constant power from my deck... on 20 pin connector on the deck.. this is pin/cavity # 10
I programmed this with spare fob from a 2005 civic and it worked great! Lights/horns all sound when locking.
Cheers
Old Apr 23, 2012
n8marsh's Avatar
n8marsh is an unknown quantity at this point
what did you use for a pigtail? did your keyless entry unit come with one?
Old Apr 23, 2012
n8marsh's Avatar
do you have a picture of your pin out connections? I'm trying to figure out which is which on the keyless entry unit.
wait you had a pic last night did you not?
darwin-t
Apr 18, 2015 09:29 PM
chgofirefighter
Apr 18, 2015 08:08 PM
TheRubixHorse
Apr 17, 2015 08:55 AM
jackoncruzpr
Apr 16, 2015 12:29 PM
GH04si
Apr 15, 2015 08:13 PM
