right turn signal problem, intermittent
Old Mar 15, 2012
Desch's Avatar
Desch is an unknown quantity at this point
Need help. 2001 Honda civic, in accident where r/f fender pushed in and sheared off top plug to turn signal bulb, straightened pins, reattached plug and turn signal worked ok for a few days. Then, turn signal bulb stays on, and the dash indicator light for right turn signal also stays lit, no signal action. Will self correct and start working again. Also, when a/c and recirc is activated, those indicator lights flash dim to bright when right turn singal activated. No problem with left turn signal and had no problems prior to accident. Any suggestions?
Thanks, Dave
Old Mar 16, 2012
lazlong's Avatar
Re: right turn signal problem, intermittent
You've got a short in one of the wires or connectors in the wrecked area. Re-inspect and repair/replace any bad wires and connectors.
BTW: You're in the 8th/9th gen forum, you need to be in the 7th gen forum.
steveneddy
May 19, 2015 02:39 PM
Fastfebur
Apr 22, 2015 01:37 PM
blackbullet
Dec 1, 2001 03:44 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
GhettoCivic
Nov 12, 2001 03:15 PM
