Bad Cluster 888888 odometer reading
Old Feb 25, 2012
paintdrying's Avatar
paintdrying is an unknown quantity at this point
I have a 2001 honda civic lx. The problem is the odometer reads 888888, the fuel guage is not accurate, and sometimes the tach does not work, the green light around the D also blinks. Then out of nowhere everything is fine. Srs light is also on.
Alternator and battery check good. I tried the cluster test, hold the trip milage, lights on off, e ct ect. The odometer read 888888 ab trip mileage before the test. aFTER THE test the check engine light blinked 5 times. I have no codes, and the check engine light never comes on when running.
From what I have read it sounds like i need to replace the whole cluster. I have spent the better part of a day reading about this. Can someone please help me. No one has had any luck with a loose wire or bad ground, and me baging the dash yeilded no results
Old Feb 26, 2012
Re: Bad Cluster 888888 odometer reading
bump
Old Feb 28, 2012
sl33pyriceboi's Avatar
there could be a couple of things:
1. ur tach is bad
2. you have some loose wire connecting ur tach to ur ECU
3. ur multiplex is shot (rare but possible. i had to replace mine)
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
youngm
Jun 4, 2015 10:19 PM
jimmyfloyd
May 20, 2015 07:06 PM
sccarally
Texas
May 17, 2015 10:11 PM
One_PeeJay
May 17, 2015 05:31 PM
