high beams come on with low beams-PROBLEM
Old Feb 19, 2012
kb_ricerocket's Avatar
kb_ricerocket is an unknown quantity at this point
Recently, my 2004 civic lx has been having issues. the high beams come on when i turn the low beams on. But, when i turn the parking lights on, the brights do not come on. So, when i drive at night, people are always flashing their brights at me as a sign because i always have the low beams and high beams on.
Anyone have a solution???? thanks
Old Feb 19, 2012
lowlife9's Avatar
Re: high beams come on with low beams-PROBLEM
im confused did you try pushing the switch towards you is it stuck fowards ???
Old Feb 19, 2012
Push the turn signal lever away from you.
Pull the turn signal lever toward you.
Does it feel funny? Maybe the high beam switch is stuck on.
Old Feb 20, 2012
I tried pulling the lever towards me and pushing it away and that didnt change anything when the lights were set on low beams (the high beams stayed on). the lever doesnt seem to damaged in any way or stuck in any position. any other solutions or guesses???
Old Feb 20, 2012
Wiring diagram and test equipment would be next for me.
Old Feb 20, 2012
sl33pyriceboi's Avatar
do u have any modifications to ur headlights? are they stock? do u have HIDs? a relay?
etc etc...
Old Feb 22, 2012
I have a relay to my HID's. any other guesses? all help is appreciated
Old Feb 22, 2012
theres the problem. you probably have them wired incorrectly.
has this problem always happened (since you installed ur HIDs) or was this a recent problem.
Old Feb 23, 2012
I have had my HIDs for almost a year now and i just recently started having this problem.
Old Feb 25, 2012
FordSlayer's Avatar
Gangsta Sexy
FordSlayer is an unknown quantity at this point
Check the high beam relay. it could be shorting out.
Old May 21, 2012
oldpitpony's Avatar
oldpitpony is an unknown quantity at this point
Hmm, the high beam relay ??? I have an 05 civic and the passenger side (right) hi beam was just fine but now does not come on at all. The left hi beam comes on just fine, with the low beam as a 2004-2005 setup should but I only get the low beam on the right side.
I have cleaned the contacts on the bulb connector and tried two new 9005 bulbs. I found a right and left headlight relay and swapped them with each other, no difference, is there another relay I should be checking here? Thanks
Old May 21, 2012
TFMEX's Avatar
CO&CA
TFMEX is a jewel in the roughTFMEX is a jewel in the roughTFMEX is a jewel in the rough
^^ This is your problem... your relays are shorting. they will need to be replaced.
ericaagarcia
Jun 11, 2015 11:29 AM
intensity
May 12, 2015 10:43 PM
speedracersong
Jan 27, 2002 06:28 PM
tcneo
Jan 24, 2002 06:19 PM
