Door Panel Vibration/Rattle
Old May 1, 2002
DxMaN's Avatar
DxMaN is an unknown quantity at this point
I've noticed that when my speakers in the door pump some good mid-bass the door panel tends to reverberate with the bass. I'm wondering what would be a good solution to this problem. I don't think simple sound-deading material in the door would do much since it seems like the actual plastic panel is what is doing the vibrating. It's almost like it needs to be screwed in or something, but anyone who's taken off the panel knows that it is merely 'popped' on. I'm thinking of some sort of padding between the door frame and the panel in order to keep pressure on it to reduce the space it has to vibrate, but has anyone else come up with a solution that is better?
Old May 1, 2002
mohawkboom's Avatar
Foam weather stripping.. comes in 20ft rolls. It's adhesive backed. Just tape some on where plastic parts might touch metal..
Old May 1, 2002
GoCivicRacerGo's Avatar
GoCivicRacerGo is an unknown quantity at this point
I put 2 layers of Raammat 60 on my doors, I think i have to redo the top of the door because when I play a lot of bass it still rattles there. Mohawk, any suggestions?
Old May 2, 2002
mohawkboom's Avatar
yes.. FOAM weather stripping.. it's not metal resonating..it's plastic hittin metal.. now put foam between it..plastic won't contact any metal..and there won't be any buzzing..
GotSiR
Jun 23, 2016 04:06 PM
horta1212
Aug 22, 2015 08:31 PM
j-chest
Aug 11, 2015 02:26 PM
theteju
Aug 5, 2015 06:59 PM
ballmich
Jul 9, 2015 11:59 AM
