Headlight Wiring problem..(UPDATE)
Old Nov 17, 2011
Shine.'s Avatar
Shine. is an unknown quantity at this point
Hey guys, I have a 2001 ex coupe and my passanger headlight is screwed.
I put in a set of Halos( wired perfectly) and a week or two into having them the light on that side gave out. Of course i figured hey, the bulbs were free with the light they must have blew! replaced them to have the same effect. So a couple days later the light from the halo itsself is really dim. Now i have dim lights and halos and my buddys call me cyclops. I thought it was the shitty headlight but when i put my stock one in I got the same result(dim light)! any ideas guys?...I hate being called cyclops
UPDATE: Checked every fuse, the fuses on the inside of the car are good to go, Under the hood the Red 10, Blue 15 and yellow 20 are blown! Would any of those have anything to do with the dimness of my head light?
Old Nov 17, 2011
sl33pyriceboi's Avatar
Re: Headlight Wiring problem..(UPDATE)
this is what happens when you buy/get cheap headlights. the leds will blow within a few hrs of operation.
what kind of light bulb are u now using? looks like u have an 01-03 so that means u use an H4 socket.
but with most aftermarket halo headlights, they use a H1 or H7 bulb. you prob shorted the headlight when you wried to headlights in.
post a pix of ur connection socket
Old Nov 17, 2011
Shine.'s Avatar
As a test I took out the 15 red fuse from the interior fuse box that was for "accessory power socket" and put it in the under-hood fuse box in the slot for the right headlight and everything went perfect. Im just back from a drive around testing the high and low and its all working good!
trellex
Jun 30, 2015 07:13 PM
carid
Jun 16, 2015 06:40 AM
bsmiley
Apr 27, 2015 01:27 PM
shaejb15
Apr 26, 2015 07:44 PM
NukeSilo
Nov 4, 2001 09:37 PM
