Replacing all four speakers
Old Oct 7, 2011
paladin732's Avatar
paladin732 is an unknown quantity at this point
Hi!
I recently replaced my headunit with a Pioneer Avic-X930BT. I am now looking at replacing the speakers. The front left one has been blown for awhile, and I figure might as well replace all four.
I am looking at the Pioneer TS-D1602R , everywhere I look says it will fit except crutchfield. Will it fit?
For the back speakers, it looks like they are 6x9 (despite crutchfield saying they are 6 1/2) so I am considering TS-D6902R. Would those fit?
Finally, what else is needed for the installer (I am just going to pay someone to do the install) besides ordering the speakers? Is there any installation junk needed like there was for the headunit? (head unit needed wireharness and faceplate)
Old Oct 7, 2011
Re: Replacing all four speakers
coupe has 6x9 in back, 6.5 in front. sedan has 6.5 all around.
Old Oct 7, 2011
Seby05's Avatar
Seby05 has a spectacular aura aboutSeby05 has a spectacular aura aboutSeby05 has a spectacular aura about
Nothing else is needed, just make sure that he cuts the wires as close as possible to the old ones and keeps the plug from the old ones so it'll be like stock. I just did my back ones again yesterday. I had Polk db 512's and put in alpines in the back. fronts are still polk, but the alpines sound terrific
Old Oct 10, 2011
electric130's Avatar
He'll need to use spacers on the front. Pics in my sig.
Old Oct 10, 2011
Seby05's Avatar
On mine the guy used the rim of the old ones as a spacer and it works fine lol, but yeah u right, deff need some kind of spacer forgot all about it
Old Oct 10, 2011
paladin732's Avatar
Will the pioneer 6.5 from my first post fit? Crutchfield says they are too deep but everywhere else says they are fine
Old Oct 10, 2011
did you read my DIY? it tells you how deep you can go.
Old Oct 15, 2011
MarkieMark's Avatar
MarkieMark will become famous soon enough
do you have a coupe or sedan?
you really don't need to worry about the rear speakers. i would just throw some cheap ones in the rear and get a nice pair of components up front along with a 2 ch. amp.
Old Oct 16, 2011
paladin732's Avatar
It is a sedan
Also, I did read those directions, but they confused me a bit. It looked like you said you can only do upto 1.5 deep, but then you had a 2 and added an additional .5
The ones I am looking at are(6.5 speakers)
Mounting Depth 2-3/8" Cut-Out Dimensions 5"
I THINK those are too big, so the next size down is (5.25 speakers)
Mounting Depth 2-1/4" Cut-Out Dimensions 4-3/4"
Which doesn't seem much difference. So I wonder if I can use the first ones...
Any idea?
Since its a sedan, that means 6.5 all around, right? So will the 6.5 fit all around? or do I need the 5.25? (Dimensions from pioneer's website are listed above)
thesushiboy
Apr 12, 2015 02:54 AM
SLeePeR012
Jan 7, 2002 12:24 AM
guy
Jan 6, 2002 04:39 PM
djaber
Jan 4, 2002 06:23 PM
ademarco6
Nov 16, 2001 10:19 PM
