Driver side power lock problems
Old Jul 28, 2011
Crescent's Avatar
Crescent is on a distinguished road
Heres the deal, i got powerlock in my car and the remote for it, but suddently like 2 weeks ago, it just stopped working for my driver side door, i was wondering what could do that, i cant lock my driver side door with the switch inside the car either, i gotta use my key everytime now :|
Old Jul 28, 2011
rehalsne's Avatar
rehalsne is an unknown quantity at this point
Re: Driver side power lock problems
Had the same problem....here are the links I used to repair it.
https://www.civicforums.com/forums/1...-actuator.html
Got the part at RockAuto.com. Here is a link for that:
http://www.rockauto.com/catalog/rafr...&parttype=1292
A little tough but with patience it was worth doing it myself because I'm sure the dealer would of been outrageously expensive.
Good luck!
Old Jul 28, 2011
Shift-E's Avatar
That Dude with the Questions
As for not being able to lock the door with the switch, thats a safety feature. Even if your power lock worked it wouldnt do that. It doesnt lock if the door is open if your keys are in the ignition, so you don't lock yourself out. What you need to do is pull on the handle then hit the switch if you want to lock with the door open. Or use your key from the outside once the doors closed.
Change the actuator and you'll be good. Very common problem for one of the actuators to stop working.
Old Jul 28, 2011
Crescent's Avatar
Thanks rehalsne ill look up to that
and @Shift-E yeah i know about the safety feature but i tried it when my door was closed and the keys in my hands xD but thanks for telling me about the door handle thing i didn't know that
Old Jul 28, 2011
Kennykid2002's Avatar
Kenny the Ricer
yup, just follow my guide to replace the actuator and you'd be fine
Old Mar 9, 2017
sara015's Avatar
sara015 is an unknown quantity at this point
Hi everyone, I have the same problem of driver door lock and would appreciate if anyone could help me out. I already replace the Actuator of my car Honda Civic2003 but it works in a week only. Now I could not lock the door by remote and key either. What can I do now ? As I know that going to dealer for fixing this problem is very expensive. Any recommendation is appreciated. Thanks
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Supramk3
May 11, 2015 07:55 PM
MamaBear2015
May 3, 2015 02:17 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
ej8
Apr 13, 2015 06:36 PM
