Help with wiring into fuse box
Old Jul 24, 2011
VividCivic's Avatar
VividCivic is an unknown quantity at this point
Question Help with wiring into fuse box
hi i was wondering how to wire in some led light strips into my fuse box so that they would be on when the car was on.Its for my 2005 Civic Vp coupe. the led strips are 12v i believe. So does this mean i need an add-a-fuse? if so which slot do i use.heres a picture of my fuse box.--->Click image for larger version
Old Jul 24, 2011
Shift-E's Avatar
That Dude with the Questions
Re: Help with wiring into fuse box
Where are you putting the LEDs? I think it would be easier to splice it into something that is already there and has 12v
Old Jul 24, 2011
lazlong's Avatar
You need to set up a relay circuit.
With a multi-meter or airbag safe test light (not a regular test light) probe the wires in the back of the fusebox for a wire that has voltage when the ignition is on and no voltage when the ignition is off. Splice into that and run it to terminal 85 on the relay.
Now, you see those big gold screws at the bottom of your pic? That's your 12V constant. Run a wire with an inline fuse from there to terminal 30 on the relay.
Run a wire from terminal 87 to the LEDs.
Run a wire from terminal 86 to ground.
Here's a pic to help:
Old Jul 25, 2011
VividCivic's Avatar
under glove box and steering column.
Old Jul 25, 2011
VividCivic's Avatar
alright thanks
roverben
Jan 21, 2019 05:16 PM
wankers
Jan 20, 2019 06:44 PM
Mike Garvey
Jun 7, 2015 07:25 PM
MiniMi
May 27, 2015 01:57 PM
smmahan
Apr 15, 2015 08:17 PM
