Okay to wire front and back speakers to the same output?
Old Jul 20, 2011
Lizking's Avatar
Lizking is an unknown quantity at this point
I just installed a new stereo in my 05 LX, and I noticed that the rear speakers don't work at all. The speakers work fine with the stock radio, and a multimeter tells me there is nothing wrong with the wiring harness I had to splice together. I'm going to return the radio, but it's going to be a while before I'll be able to deal with the return process. Just having the front speakers irritates the hell out of me. the sound quality is terrible and people in the back seat can't hear anything. Also, I'm starting a 1500-mile trip on friday.
tl;dr:
Aside from losing fade control and surround sound (which I don't have), is there any reason to not wire the front and back speakers to be on the same output wires?
Old Jul 21, 2011
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Re: Okay to wire front and back speakers to the same output?
You have to be careful that you aren't overloading the receiver. The safest way is to wire in series but you will lose a lot of sound. (Stereo + to 1st speaker +. 1st speaker - to 2nd speaker +. 2nd speaker - to stereo - for each side)
That being said as long as you aren't pushing it or if the speakers are 8ohm, then you will be fine wiring in parallel. (+ to + and - to - for both speakers from the receiver)
Old Jul 21, 2011
it will prolly blow the stereo. i would recommend installing the stock radio back til you can figure out the problem.
Old Jul 21, 2011
Lizking's Avatar
alright, I'd rather not risk it. What about wiring the front output to go only to the back? the back speakers have considerably better sound quality than the front ones.
Old Jul 21, 2011
yeah you can trade speakers if you want. like only hook up the rears to the front inputs. the fader will just be backwards when you adjust the radio settings.
mistermenphis22
Apr 3, 2016 08:06 AM
PimpBot5000
Nov 26, 2001 07:15 PM
BabyLX
Nov 16, 2001 05:53 PM
ademarco6
Nov 12, 2001 06:52 PM
mohawkboom
Nov 2, 2001 06:00 PM
