No Power to CD player and Power Locks (with Keyless remote)
Old Feb 22, 2011
BillaBonger22's Avatar
BillaBonger22 is an unknown quantity at this point
Hi, i have a 2002 Civic DX 4dr My Cd player has been acting weird (not reading CD when cold) So I decided to give it a gentle tap now the power to my CD player is gone and strangely enough at the same time my Power locks are not working with my keyless entry remote. I have checked the fuse under the steering wheel for my CD player and it is not blown. Any suggestions? I have been searching the web for hours and can't seem to find any.
***Power locks do work when in car and I used drivers door button***
Thanks.
Old Feb 22, 2011
SpeedDownZone's Avatar
Re: No Power to CD player and Power Locks (with Keyless remote)
Um that is wierd maybe your cd player just die or had a loose connection and when you tapped it, it fell off. Maybe.
And did you change your battery on your remote.
Old Feb 22, 2011
It's weird when I press the buttons on the remote the little red light blinks so I am assuming it still has battery life.
Old Feb 22, 2011
Does the car lights flash when you press the button
Old Feb 22, 2011
carowcliffe's Avatar
carowcliffe is an unknown quantity at this point
This actually happened to me, the car started fine, everything worked but the CD Player and locks, I was changing the battery in about a week anyway and so I suffered the "silence" and after changing the battery all was fine! Try unhooking and rehooking yours is all I can say? Can't hurt right? Goodluck!
Old Feb 22, 2011
Nope nothing happens... Just all of a sudden when this CD player problem occurred so did this.
Old Feb 22, 2011
Thanks I'll try cleaning the terminals too. I have noticed as well when starting my car the Speedo pointer as well as the rest kind of flicker or shake for a few seconds and then stop I can't explain this either it's never happened lol. I am having some bad luck, could be the extreme cold weather maybe..
Old Feb 22, 2011
Is it a stock cd player or after market I dont think honda would be so dumb to tie in the remote unlock to there factory radio. Reson I ask is beacuse my actuator has gone bad and since then I have changed my stock radio.
But still my lights flash when I press the buttons so I dont think so.
Old Feb 22, 2011
It's a stock CD player.
Old Feb 22, 2011
Did you check the fuse that is the constant power to the radio fuse because I read thats the same one for the keyless receiver.
Old Feb 22, 2011
Is that the fuse in the panel under the steering wheel for the CD player?
Old Feb 22, 2011
Its under the hood as backup try swaping that one and see what happens
Old Feb 22, 2011
Just went out and checked. It was the #9 fuse 10 amp Backup was blown so switched my 10 for Hazards and CD player and locks work now!!! So excited lol I will got replace Hazards fuse tomorrow.
Thanks for the help buddy!
Old Feb 22, 2011
No problem take care.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Youshoe
May 22, 2015 09:36 PM
davidarenberg
May 16, 2015 08:45 AM
kiluminati001
Dec 13, 2001 09:17 PM
redcivic
Bolt-on Engine Performance
17
Nov 9, 2001 07:39 PM
