Big Time Help needed with Headlights,03 civic
Old Nov 29, 2010
STROKKERMAN's Avatar
STROKKERMAN is an unknown quantity at this point
Hey guys I am having a problem with my eyes. Her is the deal. Sometimes when i start the car my DRL light comes on/off and a buzzing noise is heard behind the glove box. If i turn the headlights on the DRL light goes off and the buzzing stops. the only problem is the r.s highbeam doesnt come on all the time. If i cycle the headlight switch rapidly it may come on, or it may come on after a few seconds to minutes. This problem has been going on for a couple of months and becoming worse and more frequent as time goes by. Any ideas would be greatly appreciated.
Old Nov 29, 2010
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Re: Big Time Help needed with Headlights,03 civic
If you are hearing a buzzing behind the glovebox it sounds like the DRL relay is going bad. Try replacing it.
Or you may have a short in the bulb or the wiring near it. Try swapping bulbs and see if the problem follows.
Old Nov 29, 2010
Are the relays inside the cab or in the engine compartment ?
Old Nov 29, 2010
its a problem with canadian drl system. either the relay or module or both have the contacts break off and you need to resolder them to get it working. there are many threads on this forum about it and how to fix.
Old Nov 29, 2010
Any links to this would be a big help. Thanks guys for all your help.
Old Nov 29, 2010
search for "drl" in the advanced search tab and select "titles only" for search option. theres 3 pages of threads about various problems.
Old Nov 30, 2010
electric130's Avatar
^what he said
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
usajags84
15
Aug 19, 2015 03:12 AM
bsmiley
Apr 27, 2015 01:27 PM
civic_gt
Apr 19, 2015 08:15 AM
Myredjonda
Apr 14, 2015 07:00 PM
