Headlights/Radio/Memory?!?!?!?!?
Old Nov 29, 2010
i3oomz's Avatar
i3oomz is an unknown quantity at this point
OK so i posted a thread two days ago about my car not starting... well i figured it out the battery wasnt getting a good connection, but anyways..... i took my old stock HU out of my 2002 honda ex..... Hooked up the new radio and the subs/amp etc etc... but when i shut my car off my radios memory doesnt save? And if i have my headlights on and turn them off my radio shuts off? WTF?? AND MY REMOTE LOCK WONT WORK... YES ICUT THE OLD HARNESS, does that have something to do with these problems..?
Old Nov 29, 2010
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Re: Headlights/Radio/Memory?!?!?!?!?
Shutting off the car and losing memory means the continuous power wire is probably not hooked up right.
Not sure about the other stuff. I know many companies wired up a lot of things through the audio harness. Not sure about Hondas.
Old Nov 29, 2010
new radio has to be hooked up wrong.
Old Nov 29, 2010
i3oomz's Avatar
omg.. i dont know what to do ...lol.... its wierd tho cuz if i turn my headlights off.. my radio goes off?? something must be wired wrong
Old Nov 29, 2010
i can try and dig up the oem radio wires and what they do. then you can match them to the radio's harness wires (should be in the manual that came with the radio).
Old Nov 29, 2010
colors are given as solid/stripe. for example red/wht is a red wire with white stripe.
power and ground
switched ignition (yel/red)
battery 12v input (wht/red)
ground (blk)
speaker wires
driver door + (grn/blk)
driver door - (lt grn)
driver rear speaker + (blu/wht)
driver rear speaker - (blu/blk)
passenger rear speaker + (pnk)
passenger rear speaker - (blu/yel)
passenger door + (grn/yel)
passenger door - (gry/red)
Old Nov 29, 2010
i3oomz's Avatar
was i supposed to run a hot wire to the battery ? Is that why the radio keeps reseting on me when i turn the car off? I dont understand beacuse i hooked the radio up right.. Its weird tho because when i turn my headlights off the headunit turns off and when i turn the headlights back on the radio comes back on... LOL....
Old Nov 30, 2010
you need to have a constant power direct to the battery (with fuse) and also the ignition wire to trigger the radio on and off (not to power the stereo). it sounds like you hooked the power up to the headlight wire or something. just try again with the wiring.
Old Nov 30, 2010
electric130's Avatar
did you try to match the stock color wires to the aftermarket wires? if so, that doesn't work. if you had a stock radio, and put an aftermarket in, used an adapter harness, there shouldn't be a need to run a wire to the battery. the stock harness has a constant and a switched ignition power in it.
Old Dec 1, 2010
CraigW's Avatar
" AND MY REMOTE LOCK WONT WORK "
Check the "back up" fuse in under hood box.
