Led dash light conversion
Live for the Twisties
Re: Led dash light conversion
The clusters are so similar, I expected Honda to streamline the manufacturing process as much as possible.
First thing that came up on ebay.
http://cgi.ebay.ca/03-04-05-CIVIC-SP...#ht_863wt_1139
sl33pyriceboi,
http://www.lkqonline.com has bunch of MT speedometer at the time I bought my but when I check it, it still has lots though. Use the keyword "civic 04 speedo mt" you should see some.
search stuff like '03 civic cluster' on ebay. and '04 civic cluster' '05 civic cluster' lots of choices. try and find one that matches your current mileage.
dammit.. I wish I knew about them when I lived in western WA state.. I've had my 04-05 cluster sitting around because I couldn't find a shop to match my mileage..
sl33pyriceboi,
did it before the carputer.
I've been inspired by sl33pyriceboi's dash, I finally started my led mods tonight even though I've had everything to do it since the summer.
Will post pics later, so far I've only completed the 3 lower buttons, but I didn't shave the bulbs enough so they're all stuck on F*CK!!
be careful with uv leds if you value your eyesight lol. many of the good uv leds actually put out wavelengths in the real uv range. if you want the uv look, go with purple leds.
Haha some explanation is required I see..
I could decide what colour I liked, so I bought the cheapest LEDs I could find in a few different colours to experiment. My friends been fiddling with some red ones I got and I have blue, yellow, green, UV, white and orange here. Total cost was like $12 shipped..
Once I decide what I like I'll order some good ones.
7th gen LED mods rainbow style anyone?
On a serious note, one of my climate control buttons was working fine when I first put them back into my car. Then it turned off and it won't come back on, tested the LED and it works fine.. any ideas what I did wrong?
I thought I might have gotten the board to hot, but it worked for a few minutes no probs.
upon further investigation, there's not as many choices as there were way back when. i'd search for "01 civic reverse glow" or "01 civic guges" or similar.
when I searched for mine, I really liked these: http://cgi.ebay.com/ebaymotors/EL-WH...#ht_2578wt_939
but I hated the stupid "Hyper" in the tach section of the overlay..
my orange led dash with cheap 5mm leds is still doing okay since 2006. those buttons were hard to find room for the leds tho.
I ground the LEDs down to almost nothing with my dremel to fit them into the buttons and re-soldered one of the joints and its all good now. I'll take some pics in the dark tonight.
