Lights On Alert/Beep
Old Oct 5, 2010
Rem7mmMag's Avatar
Rem7mmMag is an unknown quantity at this point
Hi all
I did a search and didn't find anything on this.
Not sure where to even start looking for this problem but, you know the sound that beeps when you shut the car off and open the door and the lights are still on? Mine isn't working and I have had to jump the car twice because of forgeting the lights are on!
2001 Civic LX
thanks
Old Oct 5, 2010
CraigW's Avatar
Re: Lights On Alert/Beep
Does your dome light come on when the drivers door is opened and dome is set to "door" ??
If no... check the rubber covered plunger switch for drivers door.
Old Oct 21, 2010
robol's Avatar
robol is an unknown quantity at this point
yes,they do work
Old Oct 21, 2010
robol's Avatar
civic 2005 no sound when head lights on,plunger switch for driver door is working,got soud for open door and interior light,but still no warning for haed lights.
Old Oct 21, 2010
lazlong's Avatar
Service manual points to loose connections or Multiplex Control Unit (MCU). Look for loose connections at the door plunger and at the MCU (it's part of your under-dash fuse/relay box).
Old Oct 21, 2010
robol's Avatar
I ask guy from scrap yard for location of thi beep,he said that on civic 2005 basic model they dont have it. Now I m confused ?
Old Oct 21, 2010
CraigW's Avatar
So it's a DX then ?? That could be the case if so. The op has an LX which does have the warning... not sure about DX
You could make your own warning using a piezo buzzer pretty simply.
Old Oct 22, 2010
robol's Avatar
Where I can get info about piezo buzzer instalation.
Old Oct 22, 2010
CraigW's Avatar
They once were common at the auto parts store, maybe still are ??
A google search has some info.
You would need to locate the taillight switched voltage source and tap in to it (iirc it is located in the plug for the audio system, the wire color used is RED/BLACK) It has 12volts present whenever the headlight switch is on.
Old Oct 25, 2010
MegRock's Avatar
MegRock is an unknown quantity at this point
I have a 2002 Civic EX and have had the same problem (leaving my lights on because my brain is already on to the next thing when I park and no beep to remind me). I moved to San Francisco (i.e. constant fog, overcast days and need my lights on during the daylight hours) 2 years ago and have had my battery die 5/6 times since so this problem is a constant headache.
CraigW - Is there a place where I can look to find out if my car even has this feature? I bought it used and its never had the beep but might be a fuse that's dead.
Old Oct 25, 2010
CraigW's Avatar
^^ It was standard on my 05 LX...I would certainly think it would be standard on an EX.
Does the dome light come on with drivers door open ??
Old Oct 5, 2012
sharcu's Avatar
sharcu is an unknown quantity at this point
My plunger switch got disconnected. Had to fish it out and reinstall. All working now, thanks for the insight.
Old Oct 5, 2012
Ethanw's Avatar
Ethanw is an unknown quantity at this point
This is a simple fix. You can buy the Piezo buzzer at radio shack. If you do not have one nearby, you can purchase it on eBay from the Radio Shack Ebay Store for $4 with free shipping. The link to the article where I got the information is below. Good luck.
ARTICLE ON HONDCIVICFORUM.COM
76db PIEZO BUZZER-RADIO SHACK
76db PIEZO BUZZER EBAY
MyCivic
Electrical
Oct 28, 2021 11:06 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
werdnahall
May 17, 2015 11:37 AM
davidarenberg
May 16, 2015 08:45 AM
klam
Nov 16, 2001 03:36 PM
