tweeter install help 04 civic lX
Old Jul 2, 2010
antok86's Avatar
antok86 is an unknown quantity at this point
i have an 04 civic lx with after market head unit with a diamond audio d6 sub and a mrp-m500 alpine amp. i have a chance to get my hands on stock 05 civic EX tweeters with the door sails and all. looks like i can just snap them in place from my stock sail panel. how or what would i need to get this to work? are the panels differnt from LX and EX?
Old Jul 2, 2010
bobbyg5502's Avatar
bobbyg5502 is an unknown quantity at this point
Re: tweeter install help 04 civic lX
The EX tweeters are direct fit. You have to splice into the front door speakers, however, to power them. It is worth it; much better sound.
Old Jul 3, 2010
so long as you have a coupe. the pods do not fit sedans.
Old Jul 5, 2010
antok86's Avatar
any tutorial how to easily access the front speaker wires?
Old Jul 6, 2010
buckshizzo's Avatar
buckshizzo is a jewel in the roughbuckshizzo is a jewel in the roughbuckshizzo is a jewel in the rough
You have to take off the door panels to access the speaker wire.
Old Jul 6, 2010
antok86's Avatar
so im gonna splice these wires? if i use aftermarket tweeters with built in crossovers(got picture from sticky)
https://www.civicforums.com/forums/a...9&d=1170231536
Old Jul 6, 2010
well, technically you should not be splicing tweeters into the front speakers. it will change the ohm load, and the deck will suffer and possibly get fried over time. honda can get away with it because the factory tweeters have such a low power consumption that it doesnt matter much. the proper way is to get front component speakers with built-in crossovers (they wire up like a single speaker would and comes with tweeter and woofer as a set), or run the 4 speakers off an external amp and the tweeters off the deck power.
Old Jul 7, 2010
antok86's Avatar
i ended up with just the sails with no tweeters. but i do have these tweeters
http://www.pioneerelectronics.com/PU.../TS-T110?tab=B can that be spliced into the speaker wire?
Old Jul 8, 2010
i would not recommend it
Old Jul 9, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
I would go with a component system with crossovers, just change the door speakers and then run the wires off the cross over to the new tweeters.
bsmiley
Apr 27, 2015 01:27 PM
vtechcivic
Apr 21, 2015 06:58 PM
toastyghosty
32
Dec 26, 2001 02:03 AM
aZnVoYCe
Dec 7, 2001 12:41 AM
SneakerPimp
Nov 5, 2001 10:49 PM
