intermittent gauge fail(speedometer, tachometer, oil gauge)
Old Jun 30, 2010
tylest's Avatar
tylest is an unknown quantity at this point
I have a civic 2001 ex. Auto Transmission. Recently, I encountered intermittent gauge fails (all of them, speedo, tacho.....)
Everything is normal in day time. It happens after dark, 10 PM or later. Quite repeatable. I turn on the engine. I see nothing. But everything works. Works I mean such as, mileage meter is correct in the morning; trip meter mileage number is correct. It is just the gauges. I see nothing there.
Everything goes back in the morning, afternoon.
I am guessing it is something related to temperature and cluster?
I am trying by myself.
Anything would help before I go to the dealer. Thanks.
Old Jun 30, 2010
tylest's Avatar
Re: intermittent gauge fail(speedometer, tachometer, oil gauge)
Day temperature is 80-97; Night is 60-70.
thanks.
Old Jun 30, 2010
Could be as simple as shoddy wire connections. Look behind your glove box and the plugs going into your cluster for anything that might look awry
Old Jun 30, 2010
tylest's Avatar
@ xRiCeBoYx
Thank you. I will it and see if it solves the problem.
Old Jun 30, 2010
I know I had a problem when my tach randomly went out.. I looked behind the glovebox to see the tach signal wire more-or-less sheared. Then again, I do have a VAFC-II tapped into that wire and it was product of shoddy wiring, but that's neither here nor there.
RIPSAW
Nov 6, 2015 04:36 AM
lilrob1213
37
Jun 29, 2015 06:45 PM
JoeB16
61
Oct 16, 2003 07:58 PM
iGGySRiDe
Jan 27, 2002 04:59 PM
NeoMagus
Jan 27, 2002 02:04 PM
