Tail light problem
Old Jun 29, 2010
mcrae1965's Avatar
mcrae1965 is an unknown quantity at this point
Tail light problem
I have a 2003 Honda Civic and both tail light went out at the same time. The brake light work perfectly. I check both the interior and exterior fuse panel but I can't locate the fuse for the tail lights. Can anyone help?
Thanks. Marty
Old Jun 30, 2010
CraigW's Avatar
Re: Tail light problem
Are the licence plate lights working ??
Front parking/marker lamps ??
Old Jun 30, 2010
electric130's Avatar
did you check the bulbs? just the one filament in each could be burned out. yes, it is possible they both blew at the same time. same thing can happen with headlights. both can go at the same time. people will swear a fuse has to be blown, but it's just bad bulbs.
Poopies
Apr 20, 2017 11:36 PM
Erndog81
Oct 31, 2015 03:01 PM
shaejb15
Apr 12, 2015 11:38 AM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
