Amplifier remote wire to fuse box
Old Apr 23, 2010
Orcus332's Avatar
Orcus332 is an unknown quantity at this point
Hey guys,
I'm installing a new amp into my 05 civic EX SE and need to run the remote wire. I have a stock HU, so I don't want to go in there and cut the wires up to tap into the remote wire there. I heard you can use a fuse tap and tap into something that is only powered when the ignition is in the on position and that will tell your amp to turn on. I've seen these devices that plug directly into the fuse box and include a wire so the remote wire can be spliced in:
http://www.amazon.com/Bussmann-BP-HH...2080590&sr=8-8
However, these can only be used in slots 10A or less.
My question is, what fuse slot fits my criteria of only being on when the ignition is on, and is = or less than 10A. I've looked at my fuse diagram, and these are my options: r/c mirror, Turn light, Day light, alternator, p/w relay, ACC radio, RR wiper, and meter. All of those listed are 10 or less, i just dont know if they are always powered or not.
Thanks!
Old Apr 24, 2010
2k5reverb's Avatar
2k5reverb will become famous soon enough
Re: Amplifier remote wire to fuse box
I think the easiest spot to find a 12v signal that is only on when the car is running is the cigarette lighter socket. It's pretty easy to access.
Old Apr 24, 2010
Orcus332's Avatar
Ya i'm sure that would work, i just don't want to cut any of the factory wires. I guess I can just stuff the wire into the 15A cig lighter fuse w/ the fuse. Kinda the same thing as a fuse tap, but not as fancy. I was hoping to go for a cleaner install.
Old Apr 24, 2010
Just use a t tap
http://www.safe-n-sound1.com/images/t-tap2.jpg
cheap and easy way to tap that wire.. $3 at autozone..
Old Apr 24, 2010
Orcus332's Avatar
Any idea what gauge that I would need for the power to the cig lighter?
Old Apr 24, 2010
Orcus332's Avatar
Thanks for the help guys, I ended up getting a T-tap Size 14-18 gauge and took apart the panels to the cig outlet. It was a PITA to get the final panel off with the cig lighter, but 2 skinned knuckles later it popped off. Wasn't as easy as just "pull it up and back" like the Sticky said.
Old Sep 16, 2010
em2tk's Avatar
em2tk is an unknown quantity at this point
Damn, I'm trying to do the same, I actually did it before I came to this site, I have an 02 civic, and I tried running the remote wire to the cig acc fuse, my remote wire went up in smoke
So a 14-18 gauge is good? I used the factory remote wire that came in the amp wiring kit.
roverben
Jan 21, 2019 05:16 PM
wankers
Jan 20, 2019 06:44 PM
smmahan
Apr 15, 2015 08:17 PM
Dmitri
123
Oct 13, 2005 08:01 PM
xHoteKx
Jan 8, 2002 09:15 PM
