Remote Wiring for 2k2 civic ex
Old Jan 7, 2002
xHoteKx's Avatar
Tomotor
xHoteKx has a spectacular aura aboutxHoteKx has a spectacular aura about
i still have a stock cd receiver on my 2k2 civic ex.. i read on a post that i could run my remote wire to my cig lighter wire.. so i did that, and it blew the fuse...[IMG]i/expressions/face-icon-small-frown.gif[/IMG] is there some other place i could run the remote wire to? wutt is the acc line.... and were is it at....i need to know where this goes' someone help me ahhhhhhhhhh......
Old Jan 7, 2002
NitehawkVTEC's Avatar
NitehawkVTEC is an unknown quantity at this point
Is there no antenna power coming off the factory HU? I thought there was, but I may be wrong.
Old Jan 7, 2002
Double Post [IMG]i/expressions/face-icon-small-puke.gif[/IMG]
Old Jan 8, 2002
LJ's Avatar
LJ
Fernando The Donkey Lover
LJ is an unknown quantity at this point
nitehawk, are u talking about a power antenna lead, now why would a civic have that, we don't even have antennas!!
Old Jan 8, 2002
mohawkboom's Avatar
LJ,
we do have antennas, just not a classic whip antenna.. The antenna on our cars is integrated into the rear windshield.. looks like the rear de-fogger brown stripes but it's at the top of the rear windishield.. However it is not a powered/amplified antenna.. So no antenna power output off the HU...
Cheers
Mohawk
Old Jan 8, 2002
I know we don't have a power antenna. But I thought that I still saw the lead when I was changing my HU, I did say that I could have been wrong did I not?
Old Jan 8, 2002
EdN's Avatar
EdN
EdN is an unknown quantity at this point
My question is why did the fuse blow in the first place. I hooked mine up to the cig lighter and it worked fine. I'm worried if you put the remote wire through to the ACC line, something else may blow if you have a faulty wiring set up somewhere else.
EdN
Old Jan 8, 2002
Swifty's Avatar
From: Ricemond B.C. Canada, British Columbia, Canada
Swifty is an unknown quantity at this point
double check your connections and the routing of the wire to make sure nothing is shorting out anywhere, if the fuse is blowing as soon as you turn the car on, you probably have a short...The remote turn on should not draw more than about 1 amp...the other question is what else do you have running off of the cig lighter...cell charger, neon, or any other toys?
Old Jan 8, 2002
xHoteKx's Avatar
Tomotor
i connected the remote wire to the cig lighter.. but the wire.. the black n white one.. forgot which i connected it to.. but at the time when i turned the car on, i had nothin plugged in the cig lighter.. but i do have a radar detector and a cell phone charger plugged in there.. got one of those 2-1 cig lighter conencter thingys.. but after i replaced the fuse, everything else still works..
do i hook the remote wire to the metal parts on the back of the cig lighter or something?
Old Jan 8, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
i plugged mine straight into the ACC wire in the fusebox. works for me [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Jan 8, 2002
xHoteKx's Avatar
Tomotor
well i got the remote wire to connect to the cig lighter without blowin the fuse... but still doesnt work.. so i guess me n my friend screwed up the wiring somewhere [IMG]i/expressions/face-icon-small-frown.gif[/IMG][IMG]i/expressions/face-icon-small-frown.gif[/IMG][IMG]i/expressions/face-icon-small-frown.gif[/IMG]
gatta go back in there now...
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
carhag2000
Apr 25, 2015 01:33 PM
Linda0818
Apr 23, 2015 11:30 AM
Fastfebur
Apr 22, 2015 01:37 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
